- 30 Nov 2011
Hi guys,
so wasn't sure whether to post this in motors or here but here goes.
I've got a van that we are converting to a camper and I'm using the excuse of having everything stripped down to updgrade the audio slightly, I've got a 5 channel amp (normally 4 @ 45w + 1 sub at 320w), but the van only has space for one pair of components, so I bought a pair of JL C3's rated for 75w continuous.
The amp is bridgeable, but the default way its set up is that you can bridge the front and rear giving you up to 120w rms, but you end up with only a simgle "front" and single "rear" speaker... so that got me thinking, if I connect up front left and rear left to front left in and front right in. The front is then only receiving "left" channels and the "rear" would be both right outs from the headunit, so bridged "front" and "rear" would actually be "left" and "right". Or even just use front left as front left and front right as rear right and don't connect the rear outs at all.
Can anyone see a problem with this?
