- 7 Aug 2004
As title, I have a Punto, just a run about car. Had it around 3-4 years. Its always suffered with intermittent car battery draining, the electric warning light has always been on. In summer it doesn't really run flat (assume its the warmer weather), in winter if I do not use the car every day, the battery runs flat in 2 days
I have got around this problem by carrying a spare jump starter battery which starts it but getting bored of it now.
I took it to a car electrician in stoke who had a look at it with some fancy gear and declared he couldn't find anything draining
I have tried disconnecting the car stereo and leaving it out for a month. It wasn't that.
Tried using a volt metre to see if the battery is draining it is not (although it obviously is as its flat after 2 days in the cold)
I have replaced the battery with a amazing high quality high capacity battery, so good in fact that when I scrap or sell the car, I am going to keep the battery, its awesome.
But sadly, other than slightly extending the time it takes for it to run flat this didnt work either.
SO my only option now is to volt metre every damn electronic circuit in the car to find what the hell is draining the battery when its stood still - OCUK, how would I do this?
I had the idea of digging around in the fuse box, is there any way of like, wacking a volt meter on each circuit in there to find out whats pulling juice? Or am I imaging things that won't work ?
Any advice on how to do this would be great - again I took it to a professional who could find nothing wrong so its clearly some sort of intermittent issue that will require days of testing - so I need to find a way to test it myself and all I have is a volt meter.
