- 19 Oct 2002
- Welling/London
Well, this is a first for me!
The battery had got a bit low and was struggling to start the car to the extent that yesterday I had to get it jump started to leave a garage. I got home and put it on charge (Halfords fully automatic charger thing, just chose car & sealed battery on the switches). Left it to charge over night and just put it back into the car. Ignition came on OK and fuel pump primed but as soon as I tried to start the car the battery just exploded into hundreds of bits spraying battery acid every where!
Could this have been my fault for charging it or is it likely the battery is actually faulty? It's around 2 years old.
ouchy! I'd make sure you get your engine bay steam cleaned ASAP! Battery acid will not do anything any favours in there... First I've heard of that happening tbh. You sure you connect the +ve and -ve the right way around
