Sarin Bones. Not cheap, but well built and very adaptable. I have the three bike version, and it held three bikes securely for our staycation.
That's a good point. If the lock was around the frame it would be difficult to make away with.Most of them have several straps that would make it difficult to get away with it easily but no proper theft prevention.
Get a proper lock to tie round the frame too.
I don't think someone is going to be able to quickly run off with a 20kg bike!!!
I had a roof rack so can't really help with tail racks. But I'm sure security won't really be an issue.
Its an ebike so the motor and battery add some serious chub
The bikes go on vertically the the wheels pointing towards the car so they don’t interfere with each other, and also don’t obscure the lights or number plates.
The number plate looks pretty obscured in that picture.
I want a bike carry for my Focus, but the only ones I'll consider are either a towbar/Thule or roof bars. Everything else obscures the number plate/lights so basically needs a light bar (which necessitates towbar electrics anyway)
When I swapped cars I couldn't get a towbar fitted to the new one and.wemt with the roof bars.
Again expensive but fantastic piece of kit the Thule 598s. Four bikes, solid as a rock - you just need to watch out for low branches / car park entrances etc ....
True, hefting that above your head into the roof each time wouldn't be great![]()
