Car Charger
  • Thread starter Thread starter Deleted User 298457
  • Start date Start date
Deleted User 298457
Deleted User 298457
Hi folks,
My mum has been off the road due to a hip replacement and her Fiestas battery has died. It's unlikely she'll be driving much into the new year so looking to get the car on a charger to both a) get it back from 0, and b) trickle charge over the winter.
Is there a go to? Loads of crap on Amazon that screams "ima burn your house down".
Thanks
CTEK MXS 5.0 Battery Charger with Automatic Temperature Compensation, Black https://amzn.eu/d/aKCvQrd
Note: If the battery is too old, or too deeply discharged then it may not be recoverable. If the battery has only recently shown signs of getting low / not starting then this will probably recover it back.
In terms of keeping it charged, in case it isn't parked somewhere that's handy for plugging it in, I have been pleasantly surprised with a solar panel we bought that you plug into the cigarette lighter socket and stick on the dashboard.
We bought it because my wife's car has a parasitic drain which means it flattens the battery in about 2 weeks from a full charge (not helped by it not doing many miles, and what it does being mainly pottering around town). And it has successfully changed the situation from it needing to be charged at least every other week to - well, I can't remember the last time I charged it. Must be months ago.
And yes - we should get the drain diagnosed and fixed. But it's a freaking nightmare. The latest attempt at this the guy did come round (eventually - after weeks of delays), did the initial work, confirmed the issue is definitely a drain, arranged to come back in another work to start doing the more involved diagnosis work of finding out exactly what's causing it ... and now I haven't seen him since August.
If such a thing would be of use, let me know and I'll check the exact model we've got.
CTEK and Genius5 look about the same cost (£80ish).
Do Fiestas have a separate stop start battery I should be worried about?
Cheers chaps.
Went for the CTEK as I recognise the name from YouTube (lols) and it looks like it comes with a quick disconnect. Might be able to jerry rig something up.
Once she's back on the road I'll hook my Mercedes up I think.
