- 25 Sep 2011
So, as the title says.. I'm currently looking into a new project and putting a computer in the car.
I do IT and what not so all the IT technical bits for the machine, LCD, wireless and apple tv i can figure out.
But what I need help with is all the power for it.
How will I power it all??
The computer itself I'm just going to be using a small netbook.
Ideally, I would like all the equipment to plug into some sort of separate battery with a coupe hours charge,then that into the cars battery/power system. Is this realistic? And doable??
I'd also want all this stuf to fire up when I turn over the car and turn off again, perhaps on a 10min delay after I turn it off. I know this is doable with a normal desktop pc as I've found bit of kit that wire straight into its psu but nothing for the laptops.
Any help you can give me guys would be great and I'd love to start getting this done asap!
And I've already got a little netbook that just sits around doing sweet f.a so would be ideal to put in the car as apose to buying a whole another system.
