Car Headlight Bulb Numbers
2 Nov 2004
Watford, Herts
I need to replace the headlight bulb yet again, less than 5 months since I last did so. But I don't understand the H1,H2,H3 etc numbering system.
Its for a MK4 Ford Fiesta. Can anyone recommend a particular brand?
Phillips Vision Plus :) make sure you don't touch the glass!
edit: what year is mk4?
edit 2: and which bulb needs replacing? high beam or low beam?
Its an S Reg 98/99, the light is the standard headlight you would normally have on in the dark, not the high beam used occasionaly.
