Car Misfiring...?
28 Jan 2005
Southport
Hi all,
I am having a but of a problem again, when more then one person is in the car (not done it yet with just me in it) when I pull away at highish revs, moved out of junction when I shouldn’t of, or something of the sort it will go.... then loose a lot of power then gradually gain speed again thus making me crawl out of a junction which you can imagine is quite dangerous. It only seems to do it if there is more then one person weight in the car.
Is it misfiring or something else?
Car = Corsa 1.2 "P Reg” :(
Cheers
Does the engine sound rough when it happens?
My Elise kept on going onto 3 cylinders whenever it was wet. A new set of leads and plugs later and all is hunkey dorey :D
My Focus seems to do this every so often as well as the occasional trouble starting it. Seems to of happened ever since they changed the HT leads when it had a major service. Been too lazy to do anything about it though.
I think that the revs drop a little and i have just changed the plugs and leads what you think bout changing the dissy cap? Might make a difference?
