Hello on Sunday i went to start my car and it just died like the battery was flat (i had to reset the date and all that) but came back on with out cranking, so i checked the voltage on the battery and it had 9.78 volts in the battery so i gave it another go trying to start but same thing. so i charged the battery to 12 volts and it started right up. so i checked the battery again and got 14.68 volts( this number is higher as the alternator is charging the battery )
long story short i was wondering if this is a sine of bad starter or bad electronics?
car is a Peugeot 206 tu1jp (hfx)
Thanks Joshua
Thanks Joshua
