Just bought a car yesterday from a fairly big second hand car dealer, took it on a 25 min test drive and all seemed fine, great infact. So i bought it and drove home...
This morning its perfect..except for the gearbox
 I'll try to explain the problem...
It seems to intimitently go into 2nd + 4th + reverse (the gears going downwards, basically), yet all the gears going upwards (1st/3rd/5th) feel absolutely perfect and like normal. Sometimes when putting it in 2nd/4th/rev it just falls back into neutral and if i'm honest, the lower direction ones all feel kind of "spongey" as if they're not slotting in properly yet the 1st/3rd/5th which i'm having no problems in the slightest with all "feel" perfect/normal as you slot it in. Theres absolutely no "stiffyness" at all trying to go into any gear, just this falling back into neutral thing.
So i have 2 questions please
1) whats likely to be broken? anyone had anything similar? google isn't bringing up much apart along identical lines
2) which would be the best place to get in touch with as to getting this fixed? the garage i bought the car (which is 2 hours away
 ) or the warranty which i appear to have a very comprehensive one covering anything mechnical/electrical within a 3 month period for upto £1000.
I'm assuming its something i'm going to have to act very fast on ideally and i'd much rather get it sorted than try to push for my money back as i think the car is great.
Any help, especially regarding who to get in touch with first (car dealer or warranty place) very much appreciated
 I'll try to explain the problem...It seems to intimitently go into 2nd + 4th + reverse (the gears going downwards, basically), yet all the gears going upwards (1st/3rd/5th) feel absolutely perfect and like normal. Sometimes when putting it in 2nd/4th/rev it just falls back into neutral and if i'm honest, the lower direction ones all feel kind of "spongey" as if they're not slotting in properly yet the 1st/3rd/5th which i'm having no problems in the slightest with all "feel" perfect/normal as you slot it in. Theres absolutely no "stiffyness" at all trying to go into any gear, just this falling back into neutral thing.
 ) or the warranty which i appear to have a very comprehensive one covering anything mechnical/electrical within a 3 month period for upto £1000.I'm assuming its something i'm going to have to act very fast on ideally and i'd much rather get it sorted than try to push for my money back as i think the car is great.
 they're really quite good cars! very impressed so far, especially for the money paid.
