- 26 Mar 2010
- London
The car in question is a Ford C-MAX 2.0 diesel that vibrates when idle. As soon as the gas pedal is pushed in it disappears. Releasing or engaging the clutch in makes no difference. Although one weird thing is when you drive it for a bit, it eventually stops vibrating at idle. I've also found that if the car is left untouched for a few days it can be a slight struggle to get it to start. It starts but it feels like it's struggling to ignite. Drive it around for a bit and all these symptoms disappear. What could be causing the vibrating issue? I started thinking it might be a failing battery?
Any ideas?
Thanks!
Any ideas?
Thanks!
