Hi guys,
My bimmer wouldn't start this morning
The ignition comes on OK (radio, fans, dash etc) but when you go to start the engine, you hear a clicking - a bit like when you start a gas cooker - but the engine doesn't turn or try to.
My father thinks the starter could be stuck. I had to get a lift to work and not had a chance to look at it properly yet. It had a new battery (was original before) about a year ago so I know that is OK.
Any ideas? Its a BMW 323i Manual '99. Is this a common problem?
Cheers
The ignition comes on OK (radio, fans, dash etc) but when you go to start the engine, you hear a clicking - a bit like when you start a gas cooker - but the engine doesn't turn or try to.My father thinks the starter could be stuck. I had to get a lift to work and not had a chance to look at it properly yet. It had a new battery (was original before) about a year ago so I know that is OK.
Cheers
