Carb cleaning cost/ fuel addatives?
Man of Honour
11 Mar 2004
Has anyone used these at all or are they a waste of money?
Also how much(ball park)would a carb strip down and clean cost new jets if needed and tune up, if I just give them the bike? Xj900f.
It's not happy at low end just off Tickover.
Have you checked it properly for leaks around the inlet manifold ? They are usually rubber which gets hard goes brittle then cracks & leaks.
As for giving the bike to a shop to do I'd reckon they'd charge at least a hundred quid all in. DIY & it would be less than 20 for the jets.
£200 ? dam im in the wrong business . get some guages and balance them yourself . i doubt they need a clean if its running ok otherwise
Invest in a Haynes manual & DIY?.
If you've allready got the idea to pay some one else to take on a simple job like cleaning/setting up the carbs, then you have nothing to lose what so ever by attempting it yourself. :)
ye i know a long time ago ,i had an r6 eb5 and i had a boggie idle and i had balanced it already and cleaned it . so the shop cleaned it all again and rebalanced again although not out much at all, and was dynoed a few times to find out wer the issues wer. ended up needing new idle jets think it came in at about £190
I can DIY, allready have manual. Just cba, But if it's £200 not paying that. It's almost certainly going to need a clean.
I stripped and cleaned my carbs myself on my bandit knowing nothing about them a week before. Just bought the book for it and away I went.
Morgain carb tuner-£56
Book-£17
Good set of screwdrivers £10 (half price)
Carb cleaner can £4
I was having other problems with the running of the bike before hand and I have a aftermarket exhaust so when I reset the fueling it was off so £60 for a dyno and getting the fueling done perfectly.
I look at now as I have all the tools and the knowledge to do it again in the future on the same bike and other bikes.
Also if you take the carbs off take a good look at the inlet rubbers and make sure there are no hair line cracks as this can cause problems with the running of the bike.
The reason I think it needs a clean, is you should have seen the rust in the fuel tank and more scarily, the wrong side of the fillter all though ibviusly much smaller size particles. I do not know the history, but my guess is its been left standing ages and just a fast new brake fluid, air filter ect, to make it look better. When replacing the rear brake pads, even the bleed nipples where totally blocked up.
