Carbide SPEC-06 RGB Fan Controller location?
21 Oct 2020
I recently bought a pre-built with the Carbide SPEC-06 RGB case and I can't locate the fan controller.
Where are they usually mounted? I have checked at the back and inside the case and can't see it anywhere.
Thanks for any help.
