Hi guys,
Just took the EGR and anti-shudder vale off the Audi. EGR was caked in carbon along with the intake manifold so thought 'sod it' and took the intake manifold off it.
Now the manifold and valve ports are just as bad but with no easy access to clean.
What would you recommend to literally dissolve/make the removal of the carbon very easy ?
I've googled and Seafoam keeps popping up but it appears to be used with a running engine. And tbh, it sounds like Terraclean (I haven't researched much on these though). Would steam work?
Thanks in advance as always.
Ash
Ash
