Carbs help - Solex 32/34 Z2
21 Jan 2006
Seaham, Co. Durham
Having grown up in an age of fuel injection I now find myself with a carburated car (Peugeot 205 XS). This carb is in need of a rebuild badly so I started to strip it down last night. Apart from being a bit dirty I noticed that one of the emulsion tubes has a check ball in the end and this ball appears to be stuck solid, I couldn't get it to move at all.
I'm wondering if this ball should be able to move freely, my guess is yes it should but I'd like it if someone could confirm before I go about trying to free it off.
Spares for this carb are hard to get a hold of, I've managed to find gaskets though.
The part I'm talking about;
Thanks in advance.
Thanks for that. Rebuilt the carb with the ball stuck in the end and all works fine so it's obviously meant to be like that. How does the fuel get in the emulsion tube if it's sealed?
Fuel doesn't get into the emulsion tube! Air does!
(The purpose of the emulsion tube is to compensate for the fact that air is compressible and fuel isn't, the emulsion tube provides a mechanism for weakening the A/F mix at higher airflows to prevent it from becoming over rich)
According to my haynes carburettor manual for the Z2 -
the two perforated tubes are the primary and secondary venturi combined air corrector jets with emulsion tubes.
The curved copper tube is the pump injector.
Not sure about the tube on the rhs of you photo - hard to tell from the diagram without getting a hands on look at it.
