Card cooler question
27 Sep 2005
Hi,
My old Radion X800 Pro has started to get too loud to bear and I am wondering what the best cooler would be around the £25 area?
Thanks
My honest answer to that would be don't bother. You could add a few more £ to that £25 and just buy a MUCH better card.
is it AGP or pci-e if it's the latter you way better off investing in cheap new tech. AGP then pre owned cards of an equivilent performance would be a good option although pricey in comparison
no point spending £15 on a new hsf get a new card.
Or else take the stock fan off while keeping the stock heatsink on then getto a 80mm or 120mm fan to it.
