I have an old 9700 Pro All in Wonder in my old system and its recently started displaying artifacts on the screen (vertical lines, dashes etc).
It doesn't just happen within Windows, also during load and in BIOS screen which suggests the card itself is on the way out??
Also, it works ok for a little while from cold boot, but then the display starts turns to garbage - does that suggest a heat problem?
Am I just best giving up with the card (it's lasted me so long - cost over £300 when new
) and grabbing something else as a replacement?
Cheers
) and grabbing something else as a replacement?Cheers
