Card for Q9550
11 Aug 2013
Advice for using my old PC
its Q9550 2.83mhz, 8gb RAM, XFX6870 1gb, BeQuiet 530PSU and glorious Windows Vista.
I'm considering upgrading just the card so don't want spend too much what are good recommendations to still work with the Q9550.
I would be more concerned about motherboard compatability(it will be useful to know which motherboard you have) and OFC how much do you want to spend??
What games do you want to play??
Overclocking that CPU would also be beneficial. Something like an AMD 7950 or similar will be a good match and pretty cheep second hand, which is the only way you can buy them. I really wouldn't go much higher than that with the rest of your system specs but maybe a 290/390 could be warranted with some games. Nvidea may be better for you as they have less CPU overhead on the drivers and your CPU is your main point of concern.
PSU is a bit on the low side, more due to it's likely age than anything else as you get drop off over the years. So, for instance the PSU may only be good for 450watts if you ran it 24/7 for close to a decade. It's probably fine though.
Get rid of vista though, get 7 (or 10 maybe) you can get OEM copies for like £20 if you know where to look. I paid £25 for win10 pro but as OCUK sell it, I can't recommend competitors.
thanks for replies
mobo is Foxconn P45A-S LGA 775 and budget is around £100 for a card that improves on 6870 , i'm going to assume it'll be a second hand card, length of card is an issue, I do have a spare R9 280 but its too long inside
the Lian Li case.
So nothing bigger in size than existing 6870, any further opinions welcomed.
oh and those Windows 7 for around £20, actually i don't know where to look, anyone want suggest where i should point my sav nav towards ?
