Permabanned
- 20 Apr 2011
- Suffolk
Hey guys
My daughter has an old P4 @2.6 ghz with 1gb or ram. This is just an internet machine, but she has asked if this will play sims 3. From what I can tell running XP the CPU and ram should be fine, But the onboard graphics will not do. It has an old AGP slot, sitting here I have two old cards.
One is GeForce 6800GT with 256Mb the other is Radeon 9600xt with 128mb.
Which one of these will be best to try it with? I am guessing the 6800 as it has more memory?
Any advise would be great. Its only gaming at 1280x1024 so I hope one of those will run it OK.
Cheers
Cheers
I plan on doing this after lunch but getting an answer thats direct makes it easier. Otherwise its a bit of a pain installing two different drivers, then removing them etc.
