Card for ToR
Vague OP is vague.
What's your budget? What resolution? What's your current spec? Need little details to actually make it useful, otherwise anyone could just say get whatever is the most expensive, as more expensive is always better...
Im looking for the best card to play The Old Republic with all setting set to max. any ideas.
An Asus MARS II GeForce GTX 580 X2 would probably be the best card to play the game, it should max it out - but only just. However if you do find performance is substandard you could always add another to run in SLi - link
Vague OP is vague.
Ok, lets put it this way. which card at the lowest price can play ToR at max settings . screen rez 1920x1080 system build will be
Intel Core i7-2600K 3.40GHz
Asrock Z68 Extreme4 Gen3 Intel Z68
Corsair Force Series 3 120GB
Samsung SpinPoint F3 1TB SATA-II
Silverstone Raven 3 RV03B-W
Cooler Master GX 750W
Samsung SH-B123L/BSBP 12x BluRay ROM / 16x DVD±RW
Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 1600MHz
Corsair A70 High-Performance Dual Fan CPU Cooler
Ask in the ToR thread which is located in the PC Gaming section, a lot of members have tested the game and they can give you a rough idea.
I don't mean to be rude dude but it appears you have spent no expenses on building a top notch gaming system. There are plenty of cheap cards that will play TOR fine at that res. However your gonna want a 570 or 6950 at least for that nice build you got there.
