I purchased a second hand 460GTX. The seller stated it is fully working and was removed from a working system.
I have installed it, connected two power cables from my 700W crossair PSU. The card powers up along with the system but there is no display on the screen. The system then cuts off power, and restarts, and repeat.
I remove one of the two power cables to the graphic card and the system starts up, and stays on, without a any display.
I have a cheap £30 AMD card which runs perfectly.
What is the problem?
To note I previously had the same graphic card in my system and it worked fine.
