card help
28 Dec 2009
have just installed a Asus EAH 4890 1GB DDR5 PCIe Graphics card,
and can not get to work with any game. the game will load then as you start to play
crashs system, any help please, both power plugs are in the card and the drivers come with the card.
thanks alan
specs below
Compaq Presario SR5079UK Desktop PC
cpu intel core 2 6420 2.13
raM 2 gig
system windows vista premium service pack 2 32 bit
750 watt power
If this is the supplied power supply it may not be man enough for the job.
Is it a Mitac brand supply?
What was the graphics card you replaced?
Compaq or other oem system builders rarely factor in any spare capacity when specing power supplies etc on these desktop PCs.
I agree that the power supply sounds like a possible issue, but please check the version of the drivers that came supplied as they are often very out of date. If so download the latest and give them a go first.
hi all
its a new power pack from ****** specs below
AC INPUT: 230VAC 10A 50-60Hz Model 750UB
DC Output
Max +3.3V +5V +12V1 +12V2 -12V +5VSB
28A 30A 20A 20A 0.3A 2.5A
750 W
Dual 12v rails
thanks alan
The PSU looks like it could handle the card, I would try running CPU-Z and check if the memory on the card is dodgy next.
