card help.
20 Aug 2009
co tyrone
1 x Gigabyte F2A75M-D3H AMD A75 Chipset (Socket FM2) DDR3 Micro ATX Motherboard.
can any one advise me on what bluetooth card,would be best to use with this motherboard, thanks
Strange, what happens when inserting / removing - do you hear a windows chime at all and does it show up in Device Manger.
What phones - you will probably need to install there own software and pair the phone.
Do you have the bluetooth symbol in the corner of the task bar beside's the clock.
Yep - you will need the Nokia Data Suite, not sure on what software Blackberry uses.
Nokia data suite does not support my Phone (207) which is very annoying!
update...
did not get that bluetooth stick to work,tried all avenue's,
bought another one with driver disk all sorted.
thanks
