- 28 Jan 2015
Hi Folks,
I am considering this card as an upgrade to run a new monitor I fancy:
http://www.gigabyte.com/products/product-page.aspx?pid=5160#ov
Will this Gigabyte card enable my current set-up (shown below) to run a 34" LG-34UM-95 at full 3440x1440 screen resolution at 60 Hz? I’m not a gamer but work extensively with Photoshop and Cyberlink Power Director, all 64bit.
My current set-up would then be:
700watt power supply;
Intel i5 Haswell 4430 3GHz Quad Core 1150 Processor;
ASRock H87 Pro4 Full ATX Intel Skt 1150 Motherboard;
Team Elite 16GB DDR3 (2x8GB) 1333Mhz Memory;
Gigabyte GTX 750 Ti 2GB GDDR5 Dual-Link DVI HDMI DisplayPort PCI-E Graphics Card;
Samsung 250GB 840 Evo SSD Series Hard Drive;
LG-34UM-95 monitor.
LG won’t commit and Gigabyte just say it will display at 3440x1440 but won’t comment further. I just don't want to end up with a card that doesn't have the grunt this monitor may need to perform well.
Cheers,
Gene Stevo.
LG-34UM-95 monitor.
Cheers,
Gene Stevo.
