- 4 Jul 2006
Ok not sure if this belongs here or not but since the problem is connecting it to the motherboard I will post here.
I just bought an Advance CR-700V2 5.25" Int Multimedia Bay and it has a block connector that goes into the back of it but when it comes to plug it into the motherboard I got 4 seperate 1 pin plugs and dont have a clue where to put them.
I bought it retail but there is no pdf or instructions whatsoever.
The 4 pins are +5v / Ground / +D / -D.
Any help or advice would be much appreciated til I can get back to the shop tommorow.
