Card readers from OcUK?
ajf
ajf
30 Oct 2006
Worcestershire, UK
Do Overclockers sell internal or external card readers?
Searched but couldn't find them.
Thanks
Andrew
Thanks for the quick reply. The internal Akasa looks like what I want. Only for use on one PC.
How do the internal ones connect inside?
It says:
Compliant with USB 2.0 mainboard connection - is that an actual internal USB port or does it mean a multi pin header connection?
Andrew
