I'm looking for a card reader that'll work with the MicroSD card I'm buying, and found this one which seems to do the job. However, looking at the description of the memory card that was going to go with it, it says this:
So... does the 19-in-1 reader read the MicroSD cards natively, or does it need the use of the SD adaptor?
I'm looking for one which doesn't need an adaptor, since this is supposed to be a replacement for my last adaptor which I lost, so I want a nice big card reader that I can't misplace.
Thanks!
(Unrelated note, if I place an order with these two in, since they are out of stock will OcUK just wait for them both to be in stock before shipping them? So I can order now to make sure nobody eles grabs the next shipment?)
Each Kingston microSD comes with an SD adapter*** that gives you the convenience to use it as a full-size secure digital (SD) card in SD-enabled devices, including media readers such as Kingston's TravelLite and 19-in-1 Reader.
Thanks!
