Card recomendation
4 Oct 2010
I want a card that does not produce much heat, and is not too noisy to fit into a pentium R dual core PC. It's for a third PC, so that my children can play some simple LAN co-op games like madballs babo invasion, Alien Swarm and suchlike.
What would you recommend? Obviously cheap is good. This is not a PC that will be used much,
How over the top are you lot going? Alienswarm? On an old Pentium R? A 5450 would probably be all that's required...
OP, I'd look around for a second hand 5670 or 5750/5770. Very quiet, and will continue to play basic games for years from now.
Thanks all. A few years time isn't a problem. My 5870 will be retiring at that point :D. THe only problem is that the card has in integrated waterblock.
Perhaps I'll watercool them both at that point for quietness. That'll be an interesting project.
I'll do some research on the comparable speeds of those cards. Thanks.
This. a 5450 should be enough for alien swarm
