- 29 Sep 2010
So I've just done a spur of the moment purchase on the MM, oops.
Micro atx board, 4gb of ram (Will upgrade with another stick to 8 at some point) 955 BE quad core 3.2 ghz, which i'll probably OC to around 3.8ghz or so depending on which cooler I go for.
What gpu would be most suitable for this without there being a bottleneck?
It's going to go in a Lian Li PC-V300b (Will need some modifying as it doesn't like long cards), mainly used as a HTPC but you know how it is, once you get ideas you want bigger, so I'd like it to run some good games in the living room too.
