Card Upgrade Conundrum, Size and Spec.
8 Nov 2013
I'm about to upgrade my graphics card from an NVIDIA GeForce GTX295. The three most important bits of my spec are:
Motherboard: Gigabyte EX58-UD5
Case: Antec 300
Power Supply: Corsair 750W
I'm looking at either:
1. Gigabyte GeForce GTX 780 WindForce 3x OC Rev2.0 3072MB GDDR5 PCI-Express Graphics Card.
at http://www.overclockers.co.uk/showproduct.php?prodid=GX-114-GI&groupid=701&catid=1914&subcat=1341
or
2. Gigabyte GeForce GTX 770 WindForce 3x OC 4096MB GDDR5 PCI-Express Graphics Card.
at http://www.overclockers.co.uk/showproduct.php?prodid=GX-117-GI&groupid=701&catid=1914&subcat=1750
Will both physically fit into my case and are they both compatible with my motherboard?
I understand the PCIe 3.0 is back compatible with 2.0.
Many thanks in advance for your time.
Paul.
Power supply - Yes
Case - Can't be certain but i would say yes
Motherboard - should work as the card is PCIe
Which one i would go for? 780
