cards in case sizes
30 Nov 2007
i seem to remember i saw a thread that shown various gfx cards and showing what cases they would and wouldnt fit into.
cant remember if i saw it here tho.
any ideas where such info exists
or to the point
will a 4870 fit in a nzxt lext blackline case
There was a site i saw that listed and had diagrams of wheather an 8800GTX will fit. Have a search for it, if a 8800GTX fits then a 4870 should be ok
thanks
doesnt say if at gtx does or not
ive seen a persons sig on another forum and it states lexa blackline case with 4870
so im assuming it does fit
just wanted peace of mind and someone to tell me it does
If you want to be sure that case can handle longest graphic cards just check that it supports E-ATX motherboard.
(whose width is ~5cm bigger than ATX)
