That's them R B. They're about £ 6 cheaper per sqm. thanks!
No problem. Last place I got cloud9 11mm underlay from was eBay by the way. Delivered next day. Price has go e up slightly since this thread was made but the link is in here somewhere. Underlay is where they recoup their 'losses' on 'discount' so it really pays to get it cheap, and it's erm good stuff. You will pay around £11+m2 for an unbranded equivilent in a big shed. But they often offer fake discount.
Just thought I'd mention it as you're bound to need it!
It's still cost effective to have your independent carpet fitter supply grippers though, they're pennies and they buy them in massive bulk.
RB - We have seen the carpet we require for the whole of upstairs (4 beds, hallway / stairs.
It was in Carpetright and the code is Pleasure 730 Maple.
Any ideas if I can find it cheaper online?
yep
http://www.carpetyourroom.co.uk/detail.php?ID=747
That's £12.70 / m2 instead of £19.99
That should be a really good saving over what must be about 70+ m2? talk to your carpet fitter about how much to order and what to get pre-cut (unless you want to work it out)
trick is to use the number 'maple 730' or sometimes even '730 carpet' to find it. I directed a friend of mine to carpetyourroom and he bought his carpetright carpet from them but he called them up first to check - said they were helpful and confirmed it was the exact same one (made by regency carpets) to be sure order a sample!
The Dutch carpetright website is also useful for crosschecking:
https://www.carpetright.nl/
as it has the colour names and codes in the title. search '730' on that sitethere's a few but only one is maple.
here's the regency site too:
http://regencycarefree.co.uk/carpets/satisfaction/
you will be able to find a number of CR carpets on there. You can crosscheck the colour codes and names from the dutch site:
https://www.carpetright.nl/catalogsearch/result/?q=pleasure
to the regency site (or by jotting them down in store as annoyingly CR UK don't put the numbers on their website!)
hope that helps!
Any advice on what carpet brands are best for pet cats around the house? I'd assume ones that are not looped. Any that are stain repellant? We are thinking mixed colours be best rather than a plain cream too, because our cats are black and white!
is that regency stuff any good? does it wear fast?
What would people say are the carpet brands to go for and which are the ones to avoid?
It's very hard to weigh up what a good quality carpet is without using the price as a guide.
