My carry-on luggage is 1kg more than the allowable 5kg. Do they actually check this? (Never flown before). Not sure to it's the worth the risk or not...
AirChina via Gatwick. The laptop is weighing 2.5kgs - might have to leave it behind
Thanks! I'll leave it at home. Was only really taking it to amuse myself on the 4.5hr connection. The phone / tablet will have to do
Legroom would be more of a concern for meAirChina via Gatwick. The laptop is weighing 2.5kgs - might have to leave it behind
In my experience the bigger airlines don't seem fussed. The smaller or budget ones can be very strict. Jetstar (Australias Easyjet) encourage you to weigh it at check in if they see it and put a tag on it, in the boarding queue they come with a scale on wheels checking those without a tag and forcing those with overweight ones to go back to the counter to check them in (and pay). I avoid this by wearing my jumper or jacket, headphones around the neck and holding my ipad in my hand which saves at least a KG. If you fly KLM you can purposely go over as they let you check them into the hold for free at the desk.
I do this with my lenses. It's amazing how much you can fit into a ScottevestI knew the rough weight of all my gear like each lens, battery. Stuffed as many into my pockets as possible.
Air China would be my concern.Legroom would be more of a concern for me
