- 27 Sep 2020
I need to get a new printer as the one I have is currently not working properly, and does not recognise ink cartridges anymore.
I don't need an all singing all dancing one, just a fairly basic one for the occasional print at home, so it wont be used a huge amount.
Printer cartridges always seem to be quite expensive so I was wondering if the ink tank printers would be a better option where you refill the ink tanks?
I have not purchased a printer for years as most of the time I can get documents printed at work, so Im a bit out of the loop on what good with home printers nowadays?
Thanks
Thanks
