29 Jan 2017 at 18:12 #1 Drake5 Drake5 Soldato Joined 12 Dec 2005 Posts 14,577 Need a case for around £50 Any suggestions
29 Jan 2017 at 21:11 #2 spook2575 spook2575 Associate Joined 23 Mar 2007 Posts 1,885 Which size are you looking for and do you need external bays or room for radiators?
29 Jan 2017 at 21:24 #3 richthomuk richthomuk Associate Joined 12 Mar 2011 Posts 1,913 Location Alicante, Es / Wales Should fit most form factors
30 Jan 2017 at 19:20 #4 Drake5 Drake5 Soldato OP Joined 12 Dec 2005 Posts 14,577 Any size really Would prefer a bigger case I don't need external bays or room for radiators
30 Jan 2017 at 21:16 #5 Drake5 Drake5 Soldato OP Joined 12 Dec 2005 Posts 14,577 NZXT S340 or Enthoo Pro M
30 Jan 2017 at 22:08 #6 spook2575 spook2575 Associate Joined 23 Mar 2007 Posts 1,885 Enthoo Pro M is a good case. The gunmetal version is slightly cheaper. https://www.overclockers.co.uk/phan...metal-full-acrylic-side-window-ca-060-pt.html Also might want to consider https://www.overclockers.co.uk/cooler-master-masterbox-5-midi-tower-case-black-ca-36a-cm.html https://www.overclockers.co.uk/cors...ase-black-window-cc-9011105-ww-ca-22b-cs.html
