You can remove the fan if you want. Or just remove the cover if you're worried about space for tubes. But it's a pretty big case so you shouldn't have any issues.
was looking at the 800d god its big any suggestions on 240mm rad location in a case ie top bottom side or dose it no really matter as long as the reservoir is above the pump
