Case advice
7 Mar 2014
Bucks
Hi guys and girls
I am looking to upgrade my case. I an looking for a case with a side window but it needs to look good. I wouldn't like the carbide series as I don't like the look of it. I would like it to be as cheap as possible please
Thanks for any suggestions.
What size case do you want? ATX,mATX, itx etc?
How cheap is cheap and what parts do you want to go inside?
The comrade is a cheap case and there is a window coming for it, not sure if it will be available as a complete case+window or as a separate panel. But i will find out.
I have the Coolermaster N200, and I can say it is a very well-made case and pretty compact. It can be a bit on the noisy side, but if you have a modern motherboard or a fan controller you can fix that.
The Aerocool Qs-202 is also a good option if you want a side window. I think a solid amount of engineering has gone into Aerocool products.
Have you seen the new Corsair SPEC Series SPEC-01 or SPEC-03 cases ? I know you said you don't like the Carbide series cases, but they have gone for a different design direction with this one.
Maybe you can tell us what you want from a case:
- storage, space for graphics cards or both
- aggressive design vs classy, clean looks
- color preference
