Case Advice
I just bought one of these:
https://www.overclockers.co.uk/phanteks-enthoo-luxe-full-tower-case-black-ca-004-pt.html
After using one of these for 18 months:
https://www.overclockers.co.uk/cors...-cube-case-black-cc-9011030-ww-ca-143-cs.html
Both highly recommended but I used a fan controller to make the Corsair a bit quieter (no reason for abandoning the Corsair btw just fancied a change) but overall the Phanteks feels higher quality due to the aluminium finish. Temps are about the same in both and there's plenty of room for a lot of hardware if you need it. When you've got a 200mm fan moving air there's always going to be some noise but I'm not finding it very noticeable.
Be warned though the Phanteks case weighs an absolute ton especially when it's loaded. I built mine downstairs and had to get it up a ladder to my loft / mancave - not something I'd be keen to repeat :)
Haha thanks for that mate. I have seen a lot of good things about Phanteks actually. With this new build I was trying to look at ways of keeping sound down so keep arriving at the bequiet series.
Will have another look into Phanteks :)
Wildest how about Fractal cases m8 they are done for keeping sound down Define S looks awsome as does the R5
I would also recommend the Phanteks, it comes with a PWM fan hub. it gives great control (through your motherboard software), and can make your PC quiet.
It does largely depend on what your putting in there though? I have an Enthoo Primo with a full watercooling loop and its ultra quiet, even at full load.
If you don't care about looks just get the silverstone raven rv03 it's simply the best air cooling case performance to noise ratio.
