Hi guys - so I've got the setup as shown here: http://forums.overclockers.co.uk/showthread.php?t=18437222
The front fans (2x AP-15s) are intakes, on push into the front rad, and the bottom fan is also an intake (just to get a bit more air into the case).
The top fans (3x AP-15s) are exhaust, and on pull on the top rad, with the rear fan also an exhaust.
I've got an in-line coolant temperature sensor installed (on the input to the res, if it matters) and have been messing about running GPU stress tests to see what temperatures I get. Based on the startup figure I've seen I think my ambient temperature is ~25C give or take a few Cs.
Normally it is hovering around the 29-30C mark but this is not under load, this is minimal use (browsing etc). When I run the stress tests I can get it up to ~34C, and have even seen 38C with FurMark (seems to stress it out more than Heaven? But I am no expert on this stuff). This is with 15 minutes on each, and I wouldn't rely on me having the "right" settings to correctly test (although I tried!).
So with the usual aim for a 10C delta-T I am having a look at what might be causing this. My actual question therefore is - am I causing a problem with my current fan directions? The top rad may not be getting as cool air as it could. I'm thinking of reversing the rear fan so it's also an intake.
I know I could just try this out but the way it's installed means I have to dig around with the cable management to turn it round, so a bit fiddly. Hoping to get some feedback here first!
I have determined the sensor I have has a 10k Ohm thermistor (it states it can be used on a variety of fan controllers as mentioned, and one of those mentions that spec). I can't tell what voltage it is running at though, which I understand is a factor (5v or 12v).
