I have an In Win 303 with 7 case fans (all 120mm):
3 intake: Noctua NF-S12B, 59.2 cfm
4 extract: 3 x Antec TrueQuiet UFO, 46.3 cfm and 1 x fan supplied with case (spec unknown)
I want to achieve positive pressure but I assume that the cpu case extract fan offsets the difference between the Noctua and Antecs. This is the current setup (middle row of 3 fans are the Nitro Fury gpu fans):
Should I:
a) remove the cpu case extract fan and rely on other 3 extract fans
b) change cpu cooler and cpu case extract for Corsair H80i v2 and setup fans to intake
(https://www.overclockers.co.uk/cors...iquid-cpu-cooler-cw-9060024-ww-hs-037-cs.html)
c) leave as it is
d) or other?
Should I:
c) leave as it is
d) or other?
