My Current Airflow
Case: Coolermaster Scout
1. Push/Pull Configuration on Corsair H50 Both (120mm)
2. Original Exhaust Fan (140mm)
3. Original Intake Fan (140mm)
4. Bottom Side Panel Fan (Exhaust 120mm)
5. Intake Fan for ASUS 480 GTX
NOTE: Top Side Window Panel is currently not in use due to H50 pipes touching the side, H50 will be reseated.
My Project
1. On the H50 i have terrible fans, one is the original Corsair fan and the second is a Casecom fan i had lying around. I need 2 120mm fans preferably Black or a dark colour which will decrease temps but nice and silent
2. Can stay the same
3. Need a 140mm Fan again Silent and a dark colour (pull cool air onto the hard drive
4. Xigmatek Purple 120mm Fans (Intake, to pull cold air onto the pipes of the 480)
6. Need a 140mm or 120mm Fan again Silent and a dark colour to pull cool air into the case in general
7. Xigmatek Purple 120mm Fans (Exhaust to push out all the hot air the Nvidia card pushes out)
What do you think of the Airflow for this case? it will have 4 Intake fans and 2 Exhaust fans.
Can you guys recommend Silent but good 120mm and 140mm fans for the above please?
My Project
