really not sure. monitors arent my strong point. the main difference is it not being an IPS panel, which i know is better but i'm not 100% sure why. theres also the slight size differencehow much worse is the dell
Lancool would demolish the 430... It's an amazing case, but maybe go to the middle ground?
Get a CM690-Lite I'd say and meet somewhere in the middle for the monitor
kd
Sadly the monitor isn't 120Hz
so not worth £50??antec 900 is ancient, if you want a case with a window, get the one with cable management and black interior.
Ah yeah, missed the window bit...with a window that would be more expensive than the lancool
*edit*
ok, so im wrong, it would be a whole 1p cheaper than the lancool.
but it's only 60hz refresh ratethe OCUK Value 22" is actually a phillips monitor and not some unnamed monitor with a OCUK sticker on it.
but it's only 60hz refresh rate![]()
