Your going to have get a used motherboard for your I7 8700.Can anyone recommend a motherboard and case for the above please.
Think it's ddr4 not sure the speedOne other thing that might be a consideration, is what RAM you are using..different scenario but I can't run XMP on my really cheap second hand replacement board, it's just not supported, but it's an older platform, Skylake CPU with an H110 board.
Compatible motherboards with Intel Core i7-8700
Get compatible motherboards for Intel Core i7-8700. Filter by Socket, Form factor, Chipset, SLI Support, CrossFire Support and more.pangoly.com
Is eBay the place to go then ? Any other sites ?Your going to have get a used motherboard for your I7 8700.
The usual places but we can't name specific shops as it's against the forum rulesIs eBay the place to go then ? Any other sites ?
It means it is used, so treat it like you would any used item.(what does this mean ? )
The antenna and backplate are the most awkward to replace yourself, while manuals can be downloaded and SATA cables are plentiful. Missing M.2 screws/standoffs can be a pain.
The cost of used motherboard it mite be worth looking at selling your CPU and buying new.Thanks , think I'll keep looking
If you're willing to wait, then consider AliExpress.
I've had good experiences buying budget items from there (couple of old motherboards and GPUs).
Will work out cheaper than buying from the rainforest or the bay.
Only thing to note is that you should purchase from sellers that offer free returns.
This for example: https://www.aliexpress.com/item/1005006384806050.html
