Case and PSU
3 Dec 2024
UK
Hi looking for some guidance due to long pre-order timelines I need to change my case and PSU. Would the CORSAIR RM1000x Gold ATX 3.1 PCIe 5.1 PSU fit into the either the Phanteks Eclipse G400A or Montech KING 65 PRO allowing cables to be connected and the fan not to be restricted?
what's your current/proposed computer specs and any particular reason why you would want to change the psu and case?
Only reason I want to change is the case and PSU are on back order and currently OC have no ETA when stock will be in. Specs are -
AMD Ryzen 7 9800X3D Eight Core 5.20GHz (Socket AM5) Processor - Retail£432.491£432.49
Kingston FURY Beast EXPO RGB 32GB (2x16GB) DDR5 PC5-44800C30 6000MHz Dual Channel Kit£91.661£91.66
Asus TUF Gaming B650-Plus WIFI (Socket AM5) DDR5 ATX Motherboard£141.661£141.66
Kingston FURY Renegade 2TB PCI-e 4.0 NVMe M.2 Solid State Drive (SFYRS/2000G)£104.161£104.16
I am borrowing a 4070ti off a friend short term but will be getting a 5070 TI when they release or a 9070 depending on benchmarks.
G400A has very large clearance quoted on their website, should be no issue with any PSU.
Montech, I can't find the manufacturer's website (is it down?), but a review suggests 185mm, which is not huge, but should be enough.
I will go with the G400A :) PSU was little choice as a lot are currently on pre-order not sure if there are supply shortages at the moment.
