Due to a unexpected acquisition of 3 Swiftech VGA water blocks with 1/2” push fit hose connectors and two Laing DDC-1T push fit pumps I am looking to swap my PC over to a new case and adding a water cooling setup. My PC spec is 3 HD4870 graphics cards with a AMD 1100t CPU on a standard size ATX mother board.
I quite fancy the Coolermaster 960 II case http://www.overclockers.co.uk/showproduct.php?prodid=CA-212-CM&groupid=701&catid=7&subcat=29 though dont know if there will be enough room for all the cooling? If not can any one recommend another compact case that would do the job?
Also could any one tell me what other parts I will require to complete the water cooling side of things? Radiators, reservoirs, plumbing ect
Thanks
Thanks
