I am after a case which I am gonna be sticking my Xbox innards into which I want to be the same size as proper AV gear (dvd player, amp etc) to fit in my cabinet.
Basically the Xbox looks a little out of place in there at the moment and its odd shape means I cant stack anything on top of it which is a bit of a pain and as its primary use is as a media player then it seems apt.
So I am looking for an HTPC style case to stick the lot in. I am thinking it should have a cd drive cover (like the Lian-li style where its all hidden behind a spring loaded flap) which will save me having to perform major surgery on the existing Xbox disk drive.
Which cases would actually be the correct size for doing this?
Budget probably 60 - 100 quid but nothing to flash like the pricey silverstones as I am going to be hacking it up a bit
Finally it must be white or silver ideally to keep the missus happy.
