To make it short , had Antec 902 case witch its stock fans only at back there was h80 with push n pull exhaust , and i have 980ti reference.
Swapped case to enthoo luxe removing all hdd cages , changing 200mm intake fan to two 140mm PH-F140SP also adding two more intakes on bottom PH-F140SP.
there is also one exhaust fan PH-F140SP but on smallest rpm possible to have more positive pressure, and a 360 rad with 3x 120mm fans as exhaust on top .
And for some reason gpu is hotter and has to use more rpm speed (using 1:1 fan profile ) so it is easy to spot .
what could be the problem ? any suggestions
Ty
Ty
