Case choice
7 May 2011
Nr Basingstoke
Planning my next build and i seem to be stuck on the choice. I have narrowed it down to these two, both seem to be good cases but one is Thermaltakes answer to the CM HAF series and the other is the clean cut straight case.
Choice 1 Thermaltake Chaser MK-1
Choice 2 Coolermaster ATCS 840 (Either silver or black)
Both can be air or watercooled and it is going to house a Gigabyte 990FXA-UD7 mobo ready for bulldozer. That is as far as i have got. :confused:
The ATCS840 anyday over ANY Thermaltake case.
If you get a Silver one its more difficult to get Silver bezel drives (especially Silver Blu-ray) and if you want a sidewindow then the Silver ones from Coolermaster are nearly impossible to get.
Well as yours is the only advice i recived from this thread, i have taken your advice and i have just recived a lovely new Coolermaster ATCS 840. It is huge and loads of room for the setup that i want, love the slide out mobo tray!!. One question though? Can you get a clear side panel for the case, or is it a lazer cut and dremel job.
I will post some pics of the new case soon.
