Case choices
6 Oct 2010
Ok, So I want a case for my next build.
I want a case that can accommodate water-cooling (H100 for now) custom setup long term and fit multiple GPUs should I choose to go xfire.
Window is preferred.
£70 budget.
It's between;
Fractal arc midi R2
Bitfenix ronin.
Which out of those 2/is there any cases I'm missing that I should have a look at?
The Fractal is higher quality and is probably the best case you can buy for the money. I've just bought one for my brother's build and after experiencing it am about to buy one to upgrade my own rig.
